This topic contains 7 replies, has 3 voices, and was last updated by
devaldivia 1 year, 2 months ago.
| Author | Posts |
| Author | Posts |
| April 10, 2012 at 23:46 #15953 | |
Robert S |
Hi Milan, Have several suggestion for dev4press website: 1) Documentation page needs improvement. I always get a 404 when going past last page. Filter does not seem to work properly – eg: if I do a search for shortcodes on xScape Core | All documents – then it returns empty. 2) I would like to see a more detailed Changelog per release of your products – rather than something like “Several bugs fixed”. I would like to have a better understanding of the impact a new release will have on my sites. 3) I would like to see a facility to search the Forums. At the moment there’s no easy way to search the forums – and there might be times when something has already been resolved which people could find – and therefore save yourself some work. I know that some of these suggestions have probably been mentioned previously and that you’re a busy man and focusing on product improvements. However feedback is always a positive thing from users. Regards, |
| April 10, 2012 at 23:55 #15955 | |
MillaN |
Thanks for the suggestions! 1. This will be sored soon, most of it is fixed, and I plan to have that online next week. Milan |
| April 11, 2012 at 00:09 #15957 | |
Robert S |
Hi Milan, Re Changelogs – eg if I try and bring up changelog for xScape Core – this is what I get: (nothing on 1.8.2.4) 1.7.7.2 | 2011.06.15. xScape Framework 1.7.7.2 1.7.7.1 | 2011.09.10. xScape Framework 1.7.7.1 1.7.7 | 2011.09.08. Shared templates and loop elements 1.7.6 | 2011.08.25. xScape Framework 1.7.6 1.7.5 | 2011.08.22. xScape Framework 1.7.5 1.7.4 | 2011.08.02. xScape Framework 1.7.4 1.7.3 | 2011.06.27. xScape Framework 1.7.3 1.7.2.1 | 2011.06.14. xScape Framework 1.7.2.1 1.7.2 | 2011.06.14. xScape Framework 1.7.2 1.7.1 | 2011.06.09. xScape Framework 1.7.1 1.7.0 | 2011.06.06. First official release 1.7.0 | 2011.06.06. First official release xScape Core Changelog |
| April 11, 2012 at 00:28 #15961 | |
MillaN |
Yeah, I am behind on some change logs. I will try to update them all soon. |
| April 11, 2012 at 00:33 #15964 | |
Robert S |
Milan, Ideally the changelog is in place at the time of the release. Most themes seem to have changelogs a few months out of date. Cheers, |
| April 15, 2012 at 14:02 #16062 | |
devaldivia |
Hi Milan, as I don’t have Premium support- I can’t get into the GD Star forum, still, I had a suggestion: Amazon has a “you may also like” for when people rate an item. How about if GD Star 2 has a similar ability- since GD Star can see by cookie/IP what someone has rated something, the admin could have the ability to display correlations between different articles that have been rated to the public via a widget, shortcode, etc. Or, is that already in the works? |
| April 15, 2012 at 16:21 #16072 | |
MillaN |
This is in the plans, but I doubt it will end up in the first 2.0. |
| April 15, 2012 at 18:48 #16075 | |
devaldivia |
Good to know that it is in the plans, this would be a Great feature! Thanks! |
You must be logged in to reply to this topic.
Recent Comments
Comment added on: June 16, 2013
Comment added on: June 15, 2013
