Viewing 5 posts - 1 through 5 (of 5 total)
| Author | Posts |
| Author | Posts |
| January 29, 2012 at 18:14 #13983 Quote | |
| adbarnes | I have the gd bbpress addin with wordpress 3.3.1, BBPress 2.0.2, Elgee Elbee Theme version 1.35 and gd Attachements version 1.5.3. When ever i post a new topic or reply i do not get the attachment options to upload attachments. I have checked the forums and attachments are enabled. Any Ideas? |
| January 29, 2012 at 18:33 #13984 | |
| MillaN | Options to upload should be visible on the form before you submit the topic or reply. Maybe the theme you are using adding own templates for bbPress and they are not up to the specification. |
| January 29, 2012 at 20:52 #13985 | |
| adbarnes | Is there like a shortcode or something i need on the page or a piece in the elbee elgee theme that i need to set? I didn’t see anything in the documentation besides just plug and play in the pluggins. |
| January 29, 2012 at 21:30 #13986 | |
| MillaN | I have no idea what can be the problem. It works with anything I tested as long as the theme either uses bbPress templates or implements own with all filters and actions intact. |
| February 4, 2012 at 14:36 #14151 | |
| adbarnes | Found the problem. It appears the theme did not have all the hooks in it that it should have. I worked with Literal Barrage to get the hooks added and am testing the new version of the theme which works fine with both recaptcha and attachments. Elbee Elgee theme version 1.3.6 or greater should be working. |
You must be logged in to reply to this topic.
Recent Comments
Comment added on: May 18, 2012
Comment added on: May 17, 2012
Comment added on: May 14, 2012
