GD Products Center Pro 0.9 Beta
GD Products Center 0.9 Beta is here, bringing many changes and new features. Plugin has improved templates manager, improved products and taxonomies panels, updates to gdr2 and gdT3 libraries, improved rendering templates, several bugs fixed and much more.
Warning: Plugin is not yet completed, and it is not recommended to use it on the live websites. Right now, from all the planned features for 1.0.0 release, admin side is 90% done, and front end is 90% done.
Products Types Grid
Products Types Grid
On image above you can see improved products types grid. Both this one and taxonomies grid are updated. Templates panel now lists in more detail all available templates. Each type of template is displayed as a tab. For future 1.1.0 release I plan to add editor for each template from this panel.
New widget is added for rendering list of products. You can limit and filter products to display, similar to single product widget from before. Also, if you need to embed product info into your blog posts or some other unrelated pages, you can use new shortcode: gdpc_product, details and use are in the documentation.
As for other changes, there are number of small improvements, several bugs fixed (deleting taxonomy and product types selection in the widget), updated gdr2 and gdT3 libraries. Also, code handling custom rewrite rules is improved further. I have added functions that can be used to debug WordPress rewrite rules resolving and list of registered rewrite rules. These functions are in the Central Documentation.
There will be one more beta (0.9.5) before final, and that one will be used to finalize all templates and fix bugs. This major beta is expected in about 7 to 10 days, final should be out before the end of this month. Please report any bugs found, I am sure that more are there. I am testing plugin with different themes, but I might be missing things.
Plugin Test Drive
If you want to try out the plugin before deciding on buying, use the contact form to request demo website set up for test drive. There you can try out all our plugins and themes.
Promo coupon
If you decide to purchase plugin now, while still in development phase, a coupon is available that will give you 25% discount. This coupon is: PRODUCTSCBETA. To purchase plugin, visit the plugin editions page.
Resources
Theme Templates Integration:
https://www.dev4press.com/2011/tutorials/plugins/gd-products-center/theme-templates-integration/
Product Type Editor:
https://www.dev4press.com/2011/tutorials/plugins/gd-products-center/product-type-editor/
Plugin Info
Planned Features:
https://www.dev4press.com/2011/blog/development/planned-features-for-gd-products-center/
Plugin Information:
https://www.dev4press.com/plugins/gd-products-center/
Editions & Purchase:
https://www.dev4press.com/plugins/gd-products-center/editions/
Subscribe to Dev4Press Newsletter
Get the latest announcements, release digests, promotions and exclusive discounts, and general Dev4Press-related news straight into your mailbox.
This form collects your email (optionally your name) for the purpose of sending you newsletters. Check out our Privacy Policy for more information on how we store and manage your data. We will not send you any spam. Newsletters are sent 2 to 4 times every month.
plugins relase corsecurity 2.1
coreSecurity Pro 2.1
coreSecurity Pro version 2.1 brings one big new feature for enhancing user management and adding a powerful control to disable (and later enable) user accounts with a wide range of settings. There are many more important updates, improvements, and tweaks.
reviews important update bbpress 2 6 11
Important update: bbPress 2.6.11
After a long wait, new minor update for bbPress 2.6 is now available, and it is highly recommended to update your website to this latest version of bbPress as soon as possible.
plugins relase gd power search pro 2 7 lite 2 1 upd
GD Power Search Pro 2.7 & Lite 2.1 for bbPress
Both Lite and Pro version of GD Power Search for bbPress have been updated to fix several issues, discovered after testing with bbPress 2.6.11, including a fix for a bug that is present in bbPress plugin itself.
6 thoughts on “GD Products Center Pro 0.9 Beta”
  1. Is there any “import” feature so I can bulk add multiple products? Maybe some API for that? Or are you considering this feature?
    • I am still considering how to do it, but there will be import. I will try to push it into 1.0, if not it will remain for future versions.
      • That would be great if you could implement it into 1.0! I already found use for this plugin in 3 my future projects – it has great features. Thanks for all your work on your plugins.
        • I will try to do it soon, and there are more plans for the plugin for the future. If you have some suggestions, check out the plans, and leave comment with your ideas: http://www.dev4press.com/2011/blog/development/planned-features-for-gd-products-center/
  2. gdpc_product shortcode document is broken, also documentation links are not wroking roerly, can you fix that. I wanted to check the shortcode function but it is not showing properly.
    • Hi, thanks for reporting. It is fixed, some plugins got disabled during update yesterday, now it is OK.
Comments are closed.
WP Rocket - Make WordPress Load Fast in a Few Clicks
Grammarly - Number 1 Writing App
