Plugin Maintenance and Removal
The Tools panel, is very similar between all Dev4Press plugins, with several pages all plugins have, and some additional pages specific to individual plugins.
Tools Panel
Tools Panel
Configuration
Notifications
Using this tool, you can bulk enable or disable events for different types of notifications.
Plugin Maintenance
Recheck and Update
From this page plugin will run same process that is run on every page update.
Data Cleanup
From here, you can remove data from the Logs by event and the period.
Export Settings
All plugin settings will be exported into encrypted JSON file.
Import Settings
All, or selected, plugin settings can be imported from the unmodified encrypted JSON file.
Plugin Reset
Reset / Remove
If you want to reset plugin settings, or remove all the settings, and deactivate the plugin, you can do it from this page.
