Robots.TXT
This panel is associated with the Robots.txt feature, and will be included only if the Robots.txt feature is enabled.
On this panel you can see the status of the Robots.txt file, including the type of the file (virtual or real).
Robots.TXT Panel
Robots.TXT Panel
If you have Virtual WordPress robots file, the plugin will expand the file with extra rules, and will show full robots file on this page.
If you have real robots file in the website root directory, you will need to add rules manually, and plugin will instead show rules to add, not the full robots file content.
