Simple Meta Fields
GD Content Tools Pro plugin implements meta fields and meta boxes system. There are two types of fields available: simple and custom. This video shows how simple meta fields work.
Simple meta fields are included to allow for quick fields creation when you need a simple element for the meta box. Also, these fields are used for compatibility purposes with old GD Custom Posts and Taxonomies Tools Pro plugin.
