NEL Reports
If you are using NEL – Network Error Logging security header, with option to log NEL errors via coreSecurity Pro plugin, you will get new NEL Reports panel that shows all logged NEL errors. These NEL errors will not be visible in normal Security Log panel.
NEL Reports Panel
NEL Reports Panel
Each error report contain the Type of error, URL that has triggered the error, Status (if available – 4xx or 5xx), HTTP protocol, IP and date/time the report has been logged. Logged date/time is not the actual date/time when the error occurred in browser, because browsers don’t send these reports in real time, they can send multiple reports on a delay.
