Plugin Maintenance and Removal
The Tools panel, is very similar between all Dev4Press plugins, with several pages all plugins have, and some additional pages specific to individual plugins.
Tools Panel
Tools Panel
Plugin Maintenance
Recheck and Update
From this page plugin will run same process that is run on every page update.
Data Cleanup
This tool removes all CSP and NEL reports from the security logs.
Dictionary Cleanup
This tool can remove patterns from the Dictionary by source and type.
Export Settings
All plugin settings will be exported into encrypted JSON file.
Import Settings
All, or selected, plugin settings can be imported from the unmodified encrypted JSON file.
Plugin Reset
Reset / Remove
If you want to reset plugin settings, or remove all the settings, remove database tables added by the plugin, and deactivate the plugin, you can do it from this page.
