BBCodes
This panel allows you to control which BBCodes are active, and where and how they can be used.
BBCodes Panel
BBCodes Panel
For each BBCode, you have several options:
  • Status: Enable or disable it completely
  • Toolbar: Enable or disable BBCode button on the BBCodes Toolbar
  • Roles: Enable or disable the BBCode for every individual role
If you disable BBCode for some of the roles, that BBCode will be stripped from content before saving, if the user doesn’t have the right to use it.
And, top menu has links to panels to preview all the BBCodes and Shortcodes.
