GD bbPress Toolbox Pro and GDPR Compliance
GD bbPress Toolbox plugin doesn’t have any features that require gathering or use of website visitors personal data. But, some of the plugin features require the use of cookies.
Personal Data
No personal data is stored by this plugin.
Cookies
The plugin can use several cookies, depending on the features active, and if you want to, you can disable them:
  • gdbbx_trackingactivity{hash}: to track time of the last user activity in the forums, stores only timestamp. Default expiration time for this cookie is 1 year, and it can be adjusted in the plugin settings.
  • gdbbx_sessionactivity{hash}: to track current session activity, stores only timestamp. Default expiration time for this cookie is 60 minutes, and it can be adjusted in the plugin settings.
  • gdbbx_onlineactivity{hash}: for counting the number of online users. Default expiration time for this cookie is 180 seconds, and it can be adjusted in the plugin settings.
Value for {hash} is securely generated by WordPress own hashing algorithms, the same ones used by WordPress for own cookies.
