GD Rating System plugin and GDPR Compliance
GD Rating System Lite and Pro plugins don’t have any features that require gathering or use of website visitors personal data. The plugin is logging IP’s in certain cases. And, uses cookies for logging visitor votes.
Personal Data
No personal data is stored by this plugin.
Cookies
The plugin uses only one cookie (wp-gdrts-log) for non-logged in visitors to track votes. If you don’t allow votes for non-logged in visitors, this cookie will not be used.
IP Addresses
The plugin is logging IP’s into votes log for each vote logged. IP’s are used to prevent the duplicated voting, and it can be used to geo-locate votes on administrator request.
But, if you don’t need the actual IP’s, but you still need to ability to prevent duplicated voting, GD Rating System can replace IP’s with hashed strings. This way, you don’t store actual IP’s, and hash strings can be used to prevent duplicated voting. More information on that is available here.
