Plugin Maintenance and Removal
The Tools panel, is very similar between all Dev4Press plugins, with several pages all plugins have, and some additional pages specific to individual plugins.
Tools Panel
Tools Panel
bbPress
Recalculations
With this tool, you can perform some recalculations operations to maintain bbPress data in sync.
Close Topics
Using this tool, you can easily close old and inactive topics based on two criteria: when was topic created and when the topic was last active.
Remove Logged IPs
Using this tool, you can remove all previously logged IPs from all the forum content.
Plugin Maintenance
Recheck and Update
From this page plugin will run same process that is run on every page update.
Data Cleanup
This tool removes all orphaned and obsolete thanks and reports from the database.
Export Settings
All plugin settings will be exported into encrypted JSON file.
Import Settings
All, or selected, plugin settings can be imported from the unmodified encrypted JSON file.
Plugin Reset
Reset / Remove
If you want to reset plugin settings, or remove all the settings, remove database tables added by the plugin, and deactivate the plugin, you can do it from this page.
