Plugin Maintenance and Removal
The Tools panel, is very similar between all Dev4Press plugins, with several pages all plugins have, and some additional pages specific to individual plugins.
Tools Panel
Tools Panel
Installation
Demo Data
With this tool, you can add basic prefixes and group to have the elements quickly and start using the plugin.
Plugin Maintenance
Recheck and Update
From this page plugin will run same process that is run on every page update.
Data Cleanup
This tool removes all orphaned and obsolete thanks and reports from the database.
Export Settings
All plugin settings will be exported into encrypted JSON file.
Import Settings
All, or selected, plugin settings can be imported from the unmodified encrypted JSON file.
Plugin Reset
Reset / Remove
If you want to reset plugin settings, or remove all the settings, added by the plugin, and deactivate the plugin, you can do it from this page.
