License Code Management
Each license code can be managed from its panel. This panel shows the basic information about the license (the same as on the Licenses panel) and lists the license code activations. In the case of the membership licenses, each plugin is listed separately, and you have the list of activations for each plugin. In the case of the individual plugin license, you only see the table with activations of the license code.
The image below shows the membership license, and several plugins. Each of these plugins has been activated using the membership license code, and you can see the list of domains for every activation. Each domain shows the website status (live or development), activation date and time and actions.
Every plugin or membership license limits the number of websites/domains you can use the plugin on. A single license is for one domain, a Freelance license allows for 3 domains, a Studio license allows for 25 domains, and an Agency license has no domain limit. Any license code can be used on development or staging websites without any limit. Dev4Press License Activation can determine if the website is developing or staging and will mark the activations based on that.
You can disable any activations under certain conditions from the activations list. Any website can be removed from the activations list after 30 days of being active. And, if you deactivate a domain from this list, it can’t be reactivated for another 30 days. You can remove development activations at anytime, they are not subject to activation/deactivation restrictions.
