Dashboard
The Dashboard is the main panel to get quick started with the SweepPress plugin features, get quick access to the quick and auto sweeper, view database status and more.
Dashboard Panel
Dashboard Panel
Dashboard Widgets
Dashboard has 4 or 5 widgets, depending on plugin edition, and some of the settings.
Quick Access
This panel is useful when you are starting with the plugin, and you want to quickly access the various features. If you don’t need it, you can hide it via plugin Advanced Settings.
Quick Access
Quick Access
Plugins Status
This widget shows various status messages, including the status of the plugin license.
Plugin Features
This panel shows status of various plugin modules and counts for the available sweepers, along with the count of registered sweeper jobs.
Database Status
This widget shows overview of the database tables, sizes, rows and more, including the estimation of the database size, relevant for some of the plugin features. Statistics shows all database tables stats and WordPress Core only database tables stats.
Auto/Quick Sweeper
This widget contains both Auto Sweeper and Quick Sweeper. To get more information about them, check out this article.
Data Backup Status
If you have Backup feature enabled, the Data Backup Status widget will be included. To learn more about built-in data backup system, check out this article.
