Statistics
SweepPress plugin for WordPress collects various statistical data about each sweeper results. And, since version 5.0, plugin collects removal statistics related to removal of Options, Sitemeta and Metadata.
All the statistical data is collected on a monthly basis, and you can see overall or monthly data. And, you have the filter for the period to load on the left side of the screen.
Statistics Panel
Statistics Panel
Statistics panel shows basic statistics that counts the sources of the sweepers run, meta uns, overall statistics. And, under that you have individual sweepers statistics and Meta/Options statistics.
