Profiles Block
The Profiles block is available in Lite and Pro. First create records in Settings → Profiles using Displaying Social Profiles.
Choose profiles
Insert Profiles from the coreSocial category. In Profiles → Profiles to show, choose all records or select individual profiles. A selected-but-empty block list displays no profiles. Changes to the saved profile destinations affect the records used by the block.
Display controls
- Layout chooses icons only, labels only, or labels with icons above, left, or right.
- Style chooses Plain or Shaded.
- Label chooses Name, Followers, or Name & Followers. Follower text uses the manually entered count.
- Item Alignment controls the content inside an item where applicable.
- Justified list alignment allows the Columns choice; test the result at narrow widths.
Sizes, colors, and links
Sizes controls icon size, label font size, and corner radius. Colors controls normal and hover icon/background colors with inherit, transparent, brand, or custom choices.
Links controls the target and REL values. Use meaningful link text and verify that the destination is correct. The additional CSS control can add classes for site-specific styling.
This block does not fetch follower totals from a network and does not add social sharing actions. It links to the configured profiles. See the Profiles guide for data setup and Elementor Profiles for widget placement.
