Clickable Control
For both topics and replies, bbPress runs filters to make plain text links clickable. And each of these uses 4 functions targeting URLs, emails, FTP links and user mentions.
With GD bbPress Toolbox Pro you can disable both filters.
Clickable Filters
Clickable Filters
But, if you still want filters to run, but you want to disable some of the functions, you can do that with second set of options.
Clickable Actions
Clickable Actions
While it is quite useful to have plain links made into clickable links, it is not always desirable, and with GD bbPress Toolbox Pro you have here fine control over how clickable conversion will work.
