Close Topic Control
This is a simple feature that adds a checkbox in the reply form to close the topic.
This is useful for support forums where you reply to a topic, you consider that your reply is sufficient, and you can close the topic for any new replies after that without going through topic edit to close it.
Close Topic Control Settings
Finally, a plugin supports sending notifications to topic author once the topic is closed. If the topic is closed by topic author, notifications will not be sent.
