Forum Public
WordPress has a privacy option marking the website as public or private and uses that to discourage search engines from indexing the website. That same option is used by the bbPress to handle BuddyPress Activity integration. There might be other uses related to other plugins, but right now, only thing in bbPress core that uses this is for BuddyPress Activity integration.
This feature has only one option: to not change the privacy value, to set it as private and to set it as public.
If you are not sure about this feature, you should not use it!
