Prefixes Integration with other Plugins
GD Topic Prefix Pro for bbPress can integrate into other plugins and further improve the usability of prefixes.
GD Forum Manager for bbPress
GD Forum Manager for bbPress is a free plugin developed by Dev4Press, that allows you to edit forums and topics from the forums and topics list on the frontend, individually or in bulk.
GD Forum Manager for bbPress editor Popup with Prefix options
With this plugin, GD Topic Prefix Pro integrates into topic edit and topic bulk edit popups allowing you to change prefixes without going into full topic edit.
GD Forum Manager for bbPress is a free plugin and can be downloaded from WordPress.org plugins repository.
GD Power Search Pro for bbPress
GD Power Search Pro for bbPress is a plugin developed by Dev4Press, that implements advanced search for bbPress forums. And, it can use prefixes as a part of advanced search form.
GD Power Search Pro for bbPress Prefixes integration
You can search topics that have any prefix set, search topics that don’t have any prefix, or topics that have one of the selected prefixes.
GD Power Search Pro for bbPress is a premium plugin, but it also has Lite version that can be downloaded from WordPress.org plugins repository. Lite version doesn’t have support for Prefixes search!
