Manual rating block theme integration
This video show how you can add rating block to the theme template, customize the manual integration functions, custom styling, and positioning.
2 thoughts on “Manual rating block theme integration”
  1. Hi Thank you for the wonderful job you have been doing.
    I have a question,
    I have a number of uploaded files displayed in a table on my front page. How do I manually integrate the plugin to display the rating block for each file in the last column of the table. I am using twenty sixteen theme.
    Link: seneflshare.net
    Thanks
