Manage Sitemeta
Sitemeta Panel is used to manage non WordPress records in the WordPress Sitemeta database table.
To learn more about the process, check out this article. Also, make sure to check out the relevant settings.
Sitemeta Panel
Sitemeta Panel
The way this panel works, is exactly the same as the Options panel.
Check out the article for Options panel for more information.
