Breadcrumbs Block
The Breadcrumbs block displays one trail for the current page or other supported context. It is available in Lite and Pro. In the editor, add Breadcrumbs from the block inserter, position it in the content or template, and save your changes. See Block Editor Support for an overview.
Block controls
Select the block to show its toolbar and settings:
  • Alignment in the toolbar offers inherit, start, center, end, space evenly, space between, and space around.
  • Display provides a font-size picker with presets and a custom size.
  • Advanced → Additional CSS Class adds a class for your own styling.
The trail’s content, separator, visibility, and other shared behavior come from Settings. In the editor, the preview uses the available post context; on the front end the block renders for the current request. Preview a representative page after saving. If no trail appears, check the page’s visibility and context and ensure another method is not already rendering a duplicate.
For multiple alternative post paths, see the Pro Multi Breadcrumbs block.
