coreSocial Lite and Pro
Contents
Lite
Lite provides social sharing, the Share and Profiles blocks, their supported Elementor widgets, and the inline sharing and profiles shortcodes. You can automatically add sharing to selected post types, configure button appearance, and track internal clicks. Supported networks can also provide online counts.
Lite includes Bluesky, Twitter / X, Facebook, Tumblr, Pinterest, Reddit, LinkedIn, Flipboard, Threads, and Hacker News. Additional internal choices include Gmail, Email, Copy URL, and Print. Enabling a method and selecting it for display are separate steps.
Pro
Pro adds:
  • Explore with AI, including the Explore block, Elementor widget, shortcode, and template function.
  • Floating Bar, including desktop tab mode and a mobile bottom layout.
  • Like and QR Code buttons, plus Telegram, WhatsApp, Viber, and Messenger sharing.
  • Ordering share buttons by count and limiting initially visible buttons with a More button.
  • Direct bbPress forum and topic integration.
These additions require coreSocial Pro. Elementor and bbPress also need their own supported plugin functionality to be active.
Installing Pro source files alone does not confirm that premium features are enabled. Follow License Activation and check Account if a Pro feature is unavailable.
For choosing and placing features, continue with the Ultimate Guide.
