Dashboard and Overview
Open coreSocial → Overview for the plugin’s dashboard. It brings together status information and statistics from coreSocial’s stored tracking data. It is not a report of confirmed completed shares on every destination network.
Status and edition
Review the plugin’s status information and available setup links. Lite can also show information about upgrading to Pro. Use Account for the connected account and license actions, and License Activation if a Pro feature is missing.
Overall statistics
The overall card separates network shares, email shares, Likes, Print, Copy URL, and QR displays. In Pro it also reports Total AI Explorations separately. Network breakdowns help identify which buttons are used.
coreSocial Pro Overview showing plugin status, overall action totals, network breakdowns, and recent activity
These categories describe recorded button actions. A print dialog can be canceled, a QR code can be displayed without being scanned, and an AI link can be opened without completing a conversation. See Counts and Logging for the meanings and data sources.
Recent activity
The Last 7 days Statistics chart groups recent individual log records by day and network. It is a recent-activity view, not a breakdown of the entire aggregate count database. If individual logging is disabled, aggregate counts can continue increasing without new records appearing in this chart.
Use Shared Items to inspect content-level counts and Share Logs to inspect individual records where available. If totals are unexpected, check the count method, online-check settings, logging state, and whether records have been cleared or deleted.
After setup or an update
Use the dashboard as an entry point, then test the public front end. Verify a post’s buttons, a profile list, and any Pro feature you enabled. Dashboard totals alone do not establish that the intended block, widget, or automatic placement is visible to visitors.
