Settings Panel
Open coreSocial → Settings. The settings navigation separates global controls, network definitions, and display methods. Choose a subpanel, change the relevant options, and save before testing the public front end. Premium sections may show upgrade information in Lite.
For a task-based sequence, use Sharing Content, Displaying Social Profiles, or Explore with AI.
Basics {id=”basics”}
Logging controls individual share and Explore records. Aggregate counts and Like records continue when Active is off. Visitors IP Hash enables an IP-derived hash for anonymous duplicate-Like protection. Without it, anonymous Likes cannot be deduplicated in that way. See Counts and Logging.
Showing Counts → Method chooses online counts with an internal fallback, combined counts, an average, online only, or internal only. Short Form abbreviates and rounds large numbers for display; it does not mean the stored count has been reduced.
Share URLs controls ignored URL arguments and whether archive/search pagination affects the shared URL. These choices can change how activity is grouped. For example, excluding campaign parameters helps avoid separate current-page contexts for otherwise equivalent URLs.
Online Counts Checks enables background retrieval, optionally limits it to post-type URLs, and chooses daily or weekly check frequency. Per-network online-check settings and API requirements still apply. These checks are not real-time frontend requests.
Data
Post Title → Source chooses how the shared title is resolved. Append website name adds the site name; test the result because a title source can already include it. These settings affect sharing text and page context, not the stored WordPress title itself.
CSS and JS Files
When needed controls on-demand frontend asset loading. Leave it enabled for normal use. If a custom placement is missing styling or interaction, confirm that its assets are loaded and test this setting as part of troubleshooting. The setting does not change a block’s page context or fix an invalid provider configuration.
Display
Sharing popup sets the width and height used by ordinary share popups. Some buttons open an app, use a direct provider link, or display an internal dialog instead, so these dimensions are not a universal size control for every destination.
Advanced
Show Setup Wizard makes the wizard entry available in the administration menu. The wizard changes configuration; it is not required for placing a block or widget. See Using Setup Wizard.
Networks
Enable supported social networks and customize their names, labels, and primary/text/icon colors. Some networks have additional controls, such as account/hashtags, a Twitter/X URL choice, a Facebook API token, or Messenger’s app configuration.
Enabling a network makes it available for selection. Also select it in the specific block, widget, or automatic display method. See Networks and Internal Buttons for the full workflow and limitations.
Internal
Configure Gmail, Email, Copy URL, and Print. Pro also adds Like and QR Code. Each method has its own enable switch and applicable name, label, and color controls. These are separate from social network and AI provider selections.
Profiles
Create the saved profile records used by the Profiles block, Elementor widget, and shortcode. A record contains a network/type, identifying name, destination, manual follower count, and count label. More than one record can use the same network. Adding a record does not place a visible profile list on a page.
Follow Displaying Social Profiles for setup and placement.
Inline Styling {id=”inline-styling”}
Configure the automatic inline method’s alignment, icon/label layout, color scheme, custom colors, count visibility, font and button sizes, spacing, and shape. Pro adds count ordering and the initially visible button limit with a More button.
An individual Share block or Elementor widget also stores display controls; it does not have Explore’s Use default styling switch. Changing automatic inline defaults is not a way to overwrite every saved Share block or widget. The inline shortcode/template function uses saved defaults with its documented render overrides; see Inline Sharing Shortcode.
Inline Auto Embed
Enable Active, choose the insertion location and post types, and select the networks. Locations include before content, after content, both, or no insertion. Only enabled Networks/Internal methods are offered for selection.
Automatic insertion relies on the normal WordPress content filters for the relevant singular main query. A builder/template can need a manual block or widget instead. A post-specific inline override can also affect placement. See Sharing Content.
Inline bbPress
Direct bbPress integration requires coreSocial Pro and active bbPress.
Configure forum and topic insertion separately, with their locations and selected networks. This subpanel is hidden when bbPress is inactive. See bbPress Integration for supported locations and testing.
Floating Bar
Floating Bar requires coreSocial Pro.
Configure activation, networks, side, styling, shadow, count location, scroll trigger, small-screen behavior, and count ordering. Show as tab and Tab Size control the narrow desktop collapsed state. The Floating Bar article explains how these settings work together.
AI Networks
AI providers require coreSocial Pro.
Enable providers and customize their names, button labels, and colors. Provider enablement is separate from selection in an Explore instance. All six built-in providers are enabled by default in Pro, but visitors still need an Explore placement. See Explore with AI.
Explore with AI {id=”explore-with-ai”}
Explore requires coreSocial Pro.
Set the default prompt, alignment, layout, colors, counts, ordering, initially visible limit, sizes, spacing, and shape. Prompts support {title} and {url}. Individual Explore instances can override the prompt and styling.
The default-style behavior, provider selection, and frontend checks are covered in the Explore guide. License activation and account management remain in Account, not these settings groups.
